If you want to create a circle from three points, you can use the Circle 3 Points application. This application is also useful if you want to define a specific radius in your circle. If you want to create a circle from a single point and a defined radius, see this article.
Circle 3 Points Demo
How to Create a Circle from Three Points?
Open Application: Either from the home screen or from the side menu in CAD view.
- If you do not have the 'Circle 3 Points' in the home screen, select add shortcut and add the application shown below.
- To open it from the lefthand side menu, follow this path: Draw > Arcs and circles > Circle 3 Pts
- Select Your Three Points & Create Circle: Follow the prompts to create your circle.
Select the three points in your file that you want your circle to run through. Once selected, these points should turn red. After three points are selected, a red line should appear that connects them. To unselect the points or to start over with the selection process, simply click on another point again. Once done click on the green checkmark on the right to add the circle to your drawing.
Comments
0 comments
