What are the Tablet Specifications on my PLC 400 and PLC 600?
The PLC 400 and PLC 600 tablets are optimally designed to run the HCL software for your total stations. Below are the tablet specifications.
If you are wondering if your PLC 600 tablet is the first or second generation, simply look behind the battery bay and inspect the sticker. Second generation tablets will be written similarly to "PLC 600 (2)"
 PLC 600PLC 600 (2)PLC 400
CPU
Intel i5-10310U (Gen 10)
4 cores (8 Threads)
14th Generation Intel® Core Ultra5 135U
12 cores (14 Threads)
Intel® Core i5-7Y57 vPro
Thermal Design Power15 W28 W4.5 W
CPU Mark (Processor performance score)6443175913000
RAM8 GB (16 GB for North America)16 GB4 GB
HDD Size512 GB512 GB128 GB
Operating SystemWindows 10 LTSCWindows 11 LTSCWindows 10 Enterprise 2019 LTSC
Battery Capacity68 Wh68 Wh = "Hot-Swap" Battery Capability23 Wh
Weight1.3 kg1.3 kg0.5 kg
Drop Resistance1.8 m1.8 m 1.8 m
Wi-FiWi-Fi 6Intel Wi-Fi 6E AX211Intel Dual Band Wireless-AC 8265
BluetoothBT 5.1BT 5.3BT 4.1 Class 1
SIM4G/5G with SIM & E-SIM4G/5G with SIM & E-SIM4G LTE with Micro SIM
Operating Temperature-29°C-60°C-29°C-60°C-29°C-60°C
What does the Battery "Hot Swap" Technology Mean for the PLC 600 (2)?
When exchanging the PLC 600 (2) battery, you are able to replace the battery without shutting down or putting the device to sleep, just make sure you have another battery available that is charged. This built-in battery bridge provides up to one minute of power during the swap, enabling a continuous workflow.
Comments
0 comments
