Getting Support
Before contacting customer support, it is recommended to first use the HCL Assistant available on the Hilti Construction Layout website. The HCL Assistant provides a wide range of articles and step‑by‑step guidance covering PLT and PLC workflows, features, and common questions. In many cases, the available documentation can resolve issues quickly without further assistance.
What to Do If Additional Support Is Needed
If further assistance is required, the next step is to contact local Hilti Customer Service. Each country has a dedicated support team that can be reached through the local Hilti website. The country‑specific Hilti site lists the appropriate contact details, ensuring direct support tailored to the local region.
Local customer service agents will guide the support process and determine the most effective way to assist with the reported issue.
Support Settings Tab
The Support tab within the Settings section provides tools for advanced assistance and troubleshooting.
Remote Support via TeamViewer
To access remote support, first contact local customer service. Once you have made contact, you can open a remote support session by tapping on the red "Remote Support" icon, and proceed with the information given by the customer service agent.
- A customer service agent will provide a TeamViewer session code
- The agent will guide the setup and support process
- Temporary remote access may be used to diagnose and resolve issues
Saving Diagnostic Data
Diagnostic data can be collected directly from the Support settings.
- Select Save Diagnostic Data
- A ZIP file containing log and system data is generated
- The ZIP file should be shared with Hilti Customer Support as instructed
This information helps the support team analyze application behavior and diagnose technical issues more efficiently.
What to Prepare Before Contacting Support
To help ensure efficient and accurate assistance, it is recommended to prepare the following information before contacting Hilti Customer Support:
Device information
- PLC tablet model (PLC 400 7" (180mm) or PLC 600 (250mm))
- Connected layout tool (e.g. PLT model)
Software information
- Hilti Construction Layout (HCL) software version
- Tool firmware version
- This information is available in System Info settings
Issue description
- Clear description of the issue
- When the issue occurs (startup, connection, layout, measurement, etc.)
- Any error messages or unexpected behavior observed
Project context
- Whether the issue occurs in a specific project or across multiple projects
- Whether CAD files, control points, or cloud storage are involved
Diagnostic data (if requested)
- Diagnostic data can be generated from the Support settings using Save Diagnostic Data
- The generated ZIP file can be shared with Customer Support to assist with troubleshooting
Having this information ready helps the support team identify the issue more quickly and reduces resolution time.
How to Connect your Tablet to the Internet for Remote Support
If you're using the PLT head unit, remote support isn't possible via the tablet's internal Wi-Fi because the tool itself uses the Wi-Fi connection.
Please see this detailed article to work around this and ensure you have connection for remote support.
Comments
0 comments
