What is Auto Lock
Auto Lock automatically detects and locks onto a foil target, helping the total station stay centered without manual adjustment
- On the PLT 300, Auto Lock is always enabled and cannot be turned off
- On the PLT 400, Auto Lock can be turned on or off in General Settings or directly in the camera view
When to Manually Adjust the Laser Position Instead
If the system struggles to lock onto the foil target, you can switch to "laser mode" (PLT 300) or turn off "auto lock" (PLT 400) instead and manually move the laser to the center location of your target for measurement. You will likely find this helpful in the following situations:
- When the foil target is partially blocked or not clearly visible
- When working in tight or cluttered environments
- When reflections or lighting conditions affect Auto Lock accuracy
- For fine adjustments when the lock is slightly off center (likely due to curved surfaces or sharp angles)
Correct Use of Foil Targets for Optimal Auto Locking
- Keep a square angle between the total station and the target
- Keep the foil targets clean and free of dirt, dust, or markings
- Avoid mounting the foil targets on curved or cylindrical surfaces such as poles or columns
- Keep the distance within 30 meters for best performance
- Avoid reflective backgrounds such as glass, metal, or water surfaces
- Make sure strong sunlight or artificial light does not interfere with the telescope view
Checking the Lock
After Auto Lock engages, verify the result in the camera view. The laser should be visible on the center of the foil target. If the laser is off center, a manual correction may be required.
Manual Adjustments
If Auto Lock is not accurate, you can manually correct the alignment, as explained above.
PLT 300 Manual Adjustment Demo using Laser Mode
For PLT 300:
- Select the laser as the measuring method
- Move the laser until it is centered on the foil target
- Click the green check mark to confirm
- Measure the point
PLT 400 Adjustment Demo by Turning Off Auto Lock
For PLT 400:
Option 1:
- Move the laser to the center of the foil target
- Measure the point
Option 2:
- Open the side panel in the camera view
- Disable Auto Lock
- Manually move the camera until the laser is centered
- Measure the point
Using these methods ensures accurate centering and improves overall measurement quality when Auto Lock alone is not sufficient
Comments
0 comments
