How to Align a Prism Rod Bubble Using Vertical Alignment on PLT
Importance of Prism Rod Bubble Leveling
Before starting any point layout or staking work, it is critical that the prism rod is properly leveled using a correctly adjusted bubble.
If the prism rod is not vertical, the measured point will be offset horizontally, which can lead to inaccurate measurements and misplaced layout points.
A properly leveled prism rod allows you to:
  • Trust your measurements
  • Reduce layout errors
  • Work faster without second‑guessing results
  • Maintain consistent accuracy across the jobsite
You should always be able to use your prism rod with confidence.
How to Check if Your Prism Rod Bubble Is Accurate
You can quickly verify the accuracy of your prism rod’s leveling bubble by comparing measurements while rotating the rod.
Step-by-Step Instructions
  1. Set up your prism rod
    • Ensure the rod is properly leveled using the bubble.
    • Attach a prism securely to the top of the rod.
  2. Take an initial measurement
    • Use your total station to measure the distance to the prism.
  3. Rotate the prism rod
    • Carefully rotate the rod 180° while keeping the bubble centered.
  4. Take a second measurement
    • Measure the distance to the prism again.
  5. Compare the results
    • If both measurements match, your bubble is accurate.
    • If there is a difference, your bubble likely needs calibration.
Using HCL “Live Read” for Faster Verification
The Live Read feature via the Theodolite application in HCL makes this process even easier - no need to station the tool.
How to use Live Read
  1. Open the Theodolite application
  2. Lock onto the prism on your rod
  3. Select “Live Read:"
You will see:
  • Horizontal distance
  • Slope distance
What to look for
  • Slowly rotate the leveled prism rod.
  • Watch the live values on the screen.
If the values change while the bubble stays centered, this indicates the bubble is not correctly calibrated.
General recommendations before leveling
  • If you are checking or adjusting multiple leveling bubbles, attach all of them to the rod at the same time.
    This makes the process faster and ensures all bubbles are aligned consistently.
    • Additional Hilti leveling bubbles include the POA 36 Ball Knob () and POA 37 Bubble Adapter ( )
  • Place the leveling bubbles higher on the rod, where they are easier to see and adjust.
  • Only use leveling bubbles that have adjustment screws.
Some bubbles have no adjustment screws. These cannot be calibrated and may not be accurate. Always use bubbles that allow adjustment.
Adjustment screws located below the level bubble
Understanding the adjustment screws
Most prism rod bubbles have three adjustment screws located underneath the bubble housing.
  • Each screw tilts the bubble toward its own direction
  • Small adjustments make a big difference
  • Over‑tightening can damage the bubble or throw it out of level
Always make small, controlled adjustments.
Method 1: Leveling the prism rod using PLT Vertical Alignment
Demo:
(Recommended and most accurate)
This method uses the PLT to ensure the rod is truly vertical before adjusting the bubble.
Setup
  • Attach two prisms to the rod:
    • One near the bottom, fitted with a staking tip
    • One near the top of the rod
  • Attach the leveling bubbles to the rod
  • Place the rod on firm ground
Procedure
  1. Place the prism rod as upright as possible
  2. On the PLT, open the Align Vertical application
  3. Measure the bottom prism
  4. Move to the top prism
  5. Watch the live deviation readings
  6. Adjust the rod until the deviation reads:
    • 0.000 m, or
    • As close as possible (for example 0.001 m)
At this stage, ignore the bubble completely. The PLT is your reference for true vertical.
Adjusting the bubble
  1. Use an Allen key to slightly loosen the adjustment screws
  2. Tighten the screws one by one until the bubble centers
  3. Make small adjustments only
  4. Once centered, gently secure the screws without shifting the bubble
The bubble is now calibrated to a true vertical rod.
Method 2: Leveling the prism rod using a laser
(Alternative method)
This method is useful when a PLT is not available.
Setup
  • Use a point laser, for example PM 2‑P
  • Find a doorway, window opening, or similar vertical space
  • Place tape at the top and bottom of the opening
Procedure
  1. Place the laser so it projects vertically through the space
  2. Mark the laser point on the tape at the top and bottom
  3. Remove the laser
  4. Extend the prism rod fully between the two marks.
    • For precision, you likely would prefer to screw an additional prism rod tip (POAW45) to the top of the rod, if available ()
  5. Adjust the rod until it aligns perfectly with both points
This method helps keep the rod stable as the screws for the bubble are adjsted.
  1. Loosen the bubble adjustment screws
  2. Adjust each screw until the bubble centers
  3. Secure the screws carefully
Final checks and best practices
  • Recheck the bubble after tightening the screws
  • Periodically verify bubble accuracy, especially after:
    • Dropping the rod
    • Transporting equipment
    • Long periods of use
  • Always level the rod before staking points
A properly calibrated bubble saves time, prevents rework, and increases confidence during layout.
Additional reference
For a visual demonstration, you can refer to the following video for inspiration.
Comments
0 comments
