General Settings Overview
The General Settings tab controls how values are displayed and interpreted in HCL. It includes settings for units, language, angle display, GPS behavior, prism and target handling, and the keyboard.
General
These settings affect how measurements, coordinates, and angles are displayed throughout the application.
Heights
This setting enables the use of height values for measuring, stationing, and CAD view.
  • For most 2D layout work, this is recommended to be turned off
  • When working with 3D drawings or height‑based workflows, this must be turned on
When heights are enabled, the total station also requires a station height setup, so it knows how high it is positioned on the jobsite.
Distance Units
Choose the distance units used throughout the application, such as meters, feet, or millimeters. This affects how distances are displayed and entered.
Coord. Disp. / Input
Choose how coordinates are displayed and entered in the system.
  • NEH (North, East, Height) is the default
  • Other coordinate orders may be selected depending on project or regional standards
This setting affects coordinate input fields, point information, and CAD displays.
Decimal Format
Select whether decimal values are displayed using:
  • A period (.)
  • A comma (,)
This should match regional numeric formatting standards.
Angle Units
Choose how angles are displayed:
  • Gradians (Gon)
  • Degrees, Minutes, Seconds (DMS)
This affects all angular values shown during stationing, layout, and measurement.
Angle Resolution
Select the smallest angle resolution increment needed for your angle measurements. Higher resolution provides more detailed angular readouts.
Language
Choose the language used throughout the application. This affects menus, settings, shortcuts, and on‑screen text.
VA Zero
Choose where the vertical angle (VA) zero reference is set.
  • Horizon - The vertical angle reads as zero when the telescope is level (looking straight forward).
  • Zenith - The vertical angle reads as zero when the telescope points straight up.
This setting changes how vertical angles are interpreted and displayed. Using the theodolite application will help you visualize these angular values quickly.
GPS
These settings control how GPS information from the tablet is used to assist orientation and prism searching. See this article for a deeper understanding on how you can apply this in your workflow.
GPS
Enable or disable GPS usage. When enabled and used outdoors, GPS can help the system orient the tool toward your approximate location.
GPS Angle Sector HA / VA
Defines the horizontal and vertical angle range the tool will rotate through when GPS is used to help turn the tool toward your position before starting a prism search. Limiting this range can reduce unnecessary rotation and improve responsiveness.
Prism / Target
These settings control how the total station searches for and tracks prisms or targets.
Defines the horizontal and vertical angle range in which the total station will search for a prism or target. Smaller angle sectors can speed up target acquisition, while larger sectors increase search coverage.
Predictive Search
Select how long the system continues to predictively search for a prism or target after it is temporarily lost. This allows the tool to follow the expected movement of the prism when it is briefly obstructed.
Auto Lock on Foils
  • On the PLT 300, Auto Lock is always enabled and cannot be turned off. The toggle option will not be visible.
  • On the PLT 400, Auto Lock can be toggled on or off in General Settings or directly in the camera view
See this article for more information how to use this in your workflow.
When enabled, the system automatically detects a compatible prism foil within the camera view and moves to the center of the target. This is recommended for most layout and measurement workflows.
Keyboard
These settings control keyboard behavior and input assistance.
Keyboard Language
Choose the language used for the on‑screen keyboard. This can be different from the application language if required.
1 out of 1 found this helpful
Comments
0 comments
