PLC 600 Screen Protector - When to Replace
When working with the PLC 600 tablet, clear screen visibility is essential for accurate layout and efficient operation, especially in outdoor environments.
If you notice that the screen visibility is poor, particularly in bright sunlight, this may not be an issue with the tablet itself. In many cases, the cause is a worn or damaged screen protector.
Typical signs of a worn screen protector (POAW 131)
  • Reduced visibility in sunlight
  • A cloudy or hazy screen appearance
  • Scratches, marks, or uneven surfaces (as shown in the pictures)
  • Glare that makes it difficult to read or operate the tablet
If your screen looks similar to these conditions, it is possible to replace the PLC 600 screen protector rather than replacing the entire device.
Damaged screen protector that should be replaced
Brand new screen protector
Solution
Hilti offers a dedicated screen protector (POAW 131) for the PLC 600 tablet, designed to:
  • Maintain optimal screen clarity
  • Protect the display from scratches and wear during daily jobsite use
Replacing the screen protector can significantly improve usability and restore proper visibility.
Where to find it
You can find the official replacement on the Hilti website under:
Products → Measuring Tools & Scanners → Accessories for Measuring Tools and Scanners → Other Accessories
For example, the PLC 600 screen protector (POAW 131) is listed as an official accessory in this category.
In general, Hilti provides a range of accessories to support total station workflows and improve performance in the field.
1 out of 1 found this helpful
Comments
0 comments
