Layers Application - How to Use
The Layers application controls which layers from the HCL application and which layers from the CAD drawing are visible in the view. Layers can be enabled or disabled to focus on the information relevant to the current task.
Layers Demo
How to Use the Layers Application?
    • If you do not have the 'Layers' application in the home screen, select add shortcut and add the application shown below.
  3. Choose the Layer category: The layer category controls which type of information is displayed in the CAD view. On the right side of the screen, select the category that best fits the current task.
    • Hilti layers: Contain added control points and layout points created within the application. This also includes any linework that you created within the HCL application.
    • CAD layers: Contain elements that originate from the imported CAD drawing. You will only be able to turn these on and off, rather than delete or edit. HCL will not allow modifications of the original design you import to reduce potential errors or mistakes.
  4. Manage Layers: Layer management options are available only for Hilti point layers and allow control over how points are organized.
    • Plus icon: Add additional layers for points.
    • Edit button: Modify the selected layer properties.
    • Delete button: Remove the selected layer from the project.
  5. Select Layers to View: Layer visibility determines which information is shown in the current view.
    • Use the eye icon to show or hide individual layers.
    • Hidden layers remain available and can be re‑enabled at any time.
'Layers' application shortcut icon:
Selecting the Layers application from the side menu in CAD view:
CAD view displayed after the Layers application is selected:
Managing your Layers
In the Layers window, you will see the options to add, edit, or delete layers. Remember, these options only apply for the Hilti layers. The original CAD layers cannot be edited, they can only be turned on and off from view.
When adding or editing layers, the following window will appear:
Please name the layer as needed, and select the color you would like the layer to appear as.
Important notes for working with the Hilti Layers Tab:
  1. Layer Color: As of the current time of writing, the color of the layer will not yet change the colors of points or lines in your drawing. It may affect, however, the colors of line work that has been brought in from Hilti's desktop software, PLO, if it has been used. Future releases will update this to allow colors to be used more broadly with points and lines created on the tablet.
  2. Line Work: When linework is created within the HCL application (such as from the draw line application), it will default to the "Default" Hilti layer, and cannot be changed. Future releases will update this to allow line work to be created on specific layers, if needed.
  3. Default Layer: The Hilti Default layer cannot be edited or deleted. The color must remain black, and the name must remain "default."
  4. Deleting Layers: In order to delete a layer, you must make sure all like work (if applicable) and points have been removed from it before doing so. You can change the layers of your points by using the edit point list option, or you can use the delete app if it is more convenient.
How to see light colored lines
Since changing a layer's color currently does not affect the points and lines within that layer, one way to improve the visibility of lighter colors, such as yellow, in the CAD View is to change the background color. This can be done by enabling the 3D Framing View. For detailed instructions on how to enable it, refer to this article
Examples of How Layers Work with Points (Hilti Layers)
Hilti point layers are most effective when used as an organizational and workflow tool. By separating layout points into logical layers, large projects with hundreds of points become easier to manage, review, and stake out in the field. To edit the layers your points will fall on, please see the point edit options.
Example 1: Trade‑Based Layer Organization
Layers can be created based on trade or discipline to clearly separate scope.
  • MEP – Plumbing
  • MEP – Electrical
  • MEP – HVAC
  • Structural / Anchors
  • Architectural Reference Points
This approach allows individual trades to be displayed or hidden as needed, reducing visual clutter and minimizing the risk of laying out incorrect points.
Example 2: Phase‑Based Layout Layers
For projects completed in stages, layers can reflect construction phases.
  • Phase 1 – Underground
  • Phase 2 – Slab Inserts
  • Phase 3 – Overhead Supports
  • Phase 4 – Final Equipment
Only the relevant phase layer is enabled during layout, helping crews focus on current work without distraction from future or completed points.
Example 3: Floor‑ or Zone‑Based Layers
On multi‑level or large‑footprint projects, layers can be organized by location.
  • Level 1 – East Wing
  • Level 1 – West Wing
  • Level 2 – Mechanical Room
  • Roof – Equipment Pads
This makes it easy to isolate layout points for a specific floor or area while working on site.
Example 4: Point Type Separation
Layers can be created based on the type of layout point to support different installation tasks.
  • Hanger Points
  • Sleeve Locations
  • Embed Plates
  • Equipment Centerlines
Separating point types reduces confusion and helps crews quickly identify only the points relevant to the current installation activity.
Examples of How Layers Work with CAD Layers
CAD layers are used exclusively for visibility control and cannot be edited or deleted. They are most effective for isolating reference information.
Example 1: Background Control
  • Turn off architectural finishes or furniture layers to keep the view clean.
  • Enable only structural grids and primary walls during layout.
Example 2: Coordination Views
  • Enable HVAC ductwork CAD layers while checking hanger points.
  • Disable unrelated systems to improve clarity in congested areas.
Example 3: Temporary Reference Checks
  • Enable a CAD layer to verify alignment or spacing.
  • Disable it again once layout confidence is established.
Comments
0 comments
