HCL Release Notes
To update your software, firmware, and localized how-to manual, please make sure you connect to the internet and run your updates. See this article for more information on how to stay updated.
2026.6.1 October 2026 Release
Green Layout Circle Visualization Optimized among Apps
The green layout circle (the recommended measuring area) is now much easier to visualize. In the past, this was often only able to visualize during the control point stationing process. Now, you can see the green layout circle throughout several applications in the software.
You can enable the green circle visualization via the tolerance settings for stationing applications or the screen and view settings for measuring applications:
Note: the green layout circle's area is dependent on the tolerance settings you establish.
Stationing Applications with Green Circle
Measuring Applications with Green Circle
Reporting Applications
Optimized Self-Help and other Support Options within Hilti Construction Layout
Self-help resources are much clearer and easier to access, as explained fully in this article. The following is now cleanly accessible under the help icon (question mark) at the top of the screen:
  1. Software tooltips for the screen you are currently working on
  2. Knowledge Base AI-chat bot QR code link
  3. Easy access to the software manual
  4. Easy access to begin remote support service sessions
  5. Localized folder for customized training documents for quick access
All of these features are designed to help you troubleshoot issues and investigate problems fast during your workday.
Added Audio Feedback for Point Proximity to Target Location
As explained fully in this article, users can now experience real-time audio guidance during layout tasks. Instead of continuously checking the screen, users receive acoustic feedback that helps guide them toward the target location.
What it does:
  • Provides audio feedback while moving toward points, lines, or target positions
  • Confirms when the target has been reached within the required tolerance
Supports the following applications:
Keep in mind that audio feedback is only available for 2D layout applications and does not take height differences into account. The feature is turned on within general settings.
Update Process Simplified
As explained in this article, users are now promptly notified of software, firmware, or help manual updates when opening the HCL software when connected to the internet.
In addition, updated firmware versions, when available, will automatically be downloaded in conjunction with software updates. This reduces the likelihood of needing to manually download individual software or firmware updates in the future.
Please refer to the article linked above for full how-to information on updates.
Notification screens will look similar to below:
Automatic Calibration Parameter Check
Hilti Construction Layout now enables end users to perform calibration recovery procedures that would normally have to be completed by an internal repair center. See this article for the full details.
While encountering this calibration parameter check procedure is rare, it is designed to reduce downtime and keep the tool operating in the user's hands. Users will be notified when the process is required (it can only be initiated when the software offers a notification), and it is different from a regular field calibration.
When the image below appears, simply begin the "update" process and follow the regular prompts. This will ensure your system continues to understand:
  • What is "level,"
  • How "horizontal" and "vertical" angles are defined, and
  • How to calculate accurate heights
Comments
0 comments
